I need some advice regarding recording games with Dxtory, namely Battlefield 4. I am running Windows 10 64 bit on an i7 4770 stock, reference r9 290, 8gb ram. I am trying to record at 1080p 60fps, however I NEED to get 144 fps ingame minimum. When not recording I get 150-200 fps ingame (DX11, all graphics settings low, except mesh quality ultra, resolution scale 100%, 1080p@144hz).
I have tried lagarith lossless codec; it drops my ingame framerate to around 120ish and it will record between 50-55 fps resulting in choppy video. When I try the MagicYUV lossless v1.2 codec, it records at a solid 60 fps, however my ingame fps fluctuates greatly, in some areas I get 150+, in others <100. The result is the same if I try to record in 720p@60fps.
Other recording software is not an option, as fraps does not let you record at 60 fps and play at a higher frame rate, and raptr is utter garbage. Is there anything that I can do in Dxtory so that I will be able to play at 144+ fps and record at 1080p 60 fps? Or is a capture card on a secondary PC the only option?
Screenshots of my Dxtory settings:
http://puu.sh/jNJai/3c328dc52e.png
http://puu.sh/jNJbS/72d00ac851.png
http://puu.sh/jNJcC/3608d9c557.png
http://puu.sh/jNJd8/fba957f927.png
http://puu.sh/jNJdN/145e25aa08.png
