i need Graphic card for Optiplex 980
dr backtrack
9
Hi .. my dell Optiplex 980 only has the 305 watt power supply .. so i need to Know what the best Graphic card work fine and fit with my Optiplex 980
thnaks all ..
yea but the the Radeon 7750 request 400 watt !!! .. not 305 watt
Here is motherboard
1 service mode jumper (Service_Mode)
2 RTC reset jumper (RTCRST)
3 battery socket (BATTERY)
4 PCI card connectors ( SLOT 2 & 3)
5 PCI Express x16 card connector(SLOT1)
6 PCI Express x16 (wired as x4) connector (Slot 4)
7 internal serial card connector (Serial2)
8 speaker connector (INT_SPKR)
9 PCI Express x1 wireless card connector (PCIE_WLS1)
10 thermal sensor connector THRM3)
11 fan connector (FAN_CPU)
12 power connector (12V POWER)
13 memory module connectors (DIMM_1-4)
14 front panel connector (FRONTPANEL)
15 Internal buzzer (BEEP)
16 password jumper (PSWD)
17 SATA drive connectors (SATA0-3)
18 intruder connector (INTRUDER)
19 internal USB connector (INT_USB)
20 front I/O connector(FIO)
21 power connector (MICRO_PWR)
21 is the Micro MOBO connector.
Found another picture, still hard to believe.
Free-Shipping-D441T-0D441T-CN-0D441T-DDR2-Intel-Desktop-Motherboard-For-Optiplex-980-100-tested-work.jpg
how about the SLOT u think it's will work fine the 7750 ??
Looks like it has two 12v rails at 15A and 10A which would be enough for a 7750.
Which size is your Optiplex? you'd need a low profile card if it's a small form factor
It also says that the combined 12v rails will not exceed 240w which is 20A, that's more than enough for a 7750 which runs on 75W off the PCI-E slot
also, what's your CPU?
Please have a look at the link above and check page 20 for the MINI TOWER MT dimensions if its compatible with 7750?
http://www.dell.com/downloads/global/products/optix/en/optiplex-980-tech-guide.pdf
and my CPU is Intel® Core™ i5 Processor 650 / 3.20GHz, HT, Turbo Boost, 4M, VT
x, VT
d, TXT
Regards
