Either I buy a used i5 4690k for 180usd and buy This mobo http://www.newegg.com/Product/Product.aspx?Item=N82E16813130779
OR
I buy a used I5 4690s for 155Usd and buy this mobo http://www.newegg.com/Product/Product.aspx?Item=N82E16813130731
Keep in mind i will be using my R9 fury, and other parts from this PC
whats is the better choice? 4690k with a cheap z97
or the 4690s and a cheaper Mobo
I cant decide on which one to get, im leaning more to the 4690k setup and slapping a small OC on it
But would the 4690s be good enough for my r9 fury? if so i might go the cheaper route
OR
