Question I need help figuring out why my system is slow ?
TorQueMoD
96
Hey all,
I've been having issues with my systems being slow for the past 16 months or so. I say systemS because I started with an Alienware Area 51 R5 from 2018, and I've since (in the past 12 months) replaced every component save for the PSU which I doubt is causing system lag, but maybe?
The reason I upgraded was because my programmer friend suggested it might be my PCIE lanes because I have multiple NVME drives in my system. I started with a GPU upgrade, then motherboard and CPU, then RAM. I've recentlyreplaced two of my 2TB NVME drives with one 4TB drive, so my total NVME drives are two 4TB now instead of 3.
Current hardware:
I just finished a fresh install of Windows 10 Pro 22H2 yesterday (3rd time since I started experiencing the slowdowns).
When I say slowdowns, it's mostly when running Unreal Engine 5, 3D Studio Max, or Streaming video. Everything was smooth as butter before, but now in Unreal I get constant frame drops where I'll have 120 fps, and then it suddenly drops down to 22 fps for a few seconds, regardless of the scene. in 3ds max, I get constant stuttering while scrolling in the UI.
As for Streaming, YT is mostly okay, but sometimes I get lag spikes where the video freezes, and with Netflix, Amazon, and Disney Plus, my monitors cut out to black, and then come back maybe 3 seconds later when I first load the site. Netflix stutters constantly while scrolling vids, but the other two don't. I haven't noticed any slowdown in games, but I haven't been playing much in the way of modern AAA games lately so that's likely why.
I'm thinking the issue is either still the PCIE lanes, or the GPU I bought. As I said though, the first few months after buying the GPU were great (before I upgraded any other hardware), and when I play Dead By Daylight, everything runs fine.
CPUZ Screenshot at link:
View: https://i.imgur.com/M0knIFR.png
Lutfij
You forgot to mention the make and model of the PSU in your build.
64GB Corsair Vengeance Pro DDR4 RAM (4 16GB dimms)
Can you please pass on a link to the ram kit? An image of the PCB revisions for the sticks of ram would help us two fold.
Where did you source the installer for the OS? Did you install the OS in offline mode?
It can't be lanes since I don't see any mention of lanes being shared on the motherboard's manual.
TorQueMoD
96
It's just the PSU that came with my Alienware, so I guess it's a Dell. No idea about the model. I could open it up and look tomorrow, but it worked fine for 5 years in my Alienware. I think it's an 800 Watt, but I might be wrong. I can check tomorrow if you think it's necessary.
The ram I bought 2 weeks ago and at Bestbuy, so I don't think it would be the issue since I've been experiencing similar problems for more than a year. I bought two kits of this one though: https://www.bestbuy.ca/en-ca/produc...hz-desktop-memory-cmw32gx4m2e3200c16/15300646
OS is from the Media Creation Tool so from MS. Did not install the OS in offline.
You say it can't be lanes, but I'm a little confused about the lanes... my GPU will take 16 and my OS NVME will take another 4 apparently. That's 20 right there which is the CPU limit. The other one doesn't typically run in tandem so maybe it's not an issue. I know the motherboard has more lanes on the chipset as well, that's why I bought it, but aren't they bottlenecked on their way to the CPU anyway? Like if the CPU only has 20 lanes, wouldn't it not matter it the Mobo has more than 20?
PCIe lanes from CPU and from chipset are in no way connected and wouldn't bottleneck each other. There are no GPUs with over 16PCIe lanes and no NVME SSDs with over 4. CPU actually has 24 PCIe lanes but 4 are dedicated to I/O and chipset operation.
Misgar
Respectable
Mar 2, 2023
1,609
420
2,090
I think the lack of PCIe lanes theory is a "red herring".
https://en.wikipedia.org/wiki/Red_herring
Sometimes a PCIe slot will be disabled if you add another M.2 drive, or a PCIe x16 slot might fall back to PCIe x8 working, but that shouldn't affect stability.
I'm starting to wonder if it might be the RTX 4070 because your video keeps stuttering or dissapears. Do you still have the old GPU. If so, remove the 4070 and fit the old graphics card (or any compatible GPU) and see if the system is more stable. It's easy to change RAM, or the CPU as a last resort. Take the system slowly back to its original components, to see if the fault goes away. If not it could be your software/OS or boot SSD.
It may not be true of the Alienware range, but many Dell office computers come with Dell's own proprietary power supplies, that do not conform the the "standard" ATX PSU used by most home PC builders.
If your Dell PSU does not come with a 24-way power lead for the motherboard, plus a 4 or 8-way ATX12V power lead that also plugs into the motherboard (to power the CPU) then you've got a non-standard proprietary Dell PSU. This can make changing the PSU more difficult.
Low end PSUs come with 1, 2 or 3-year warranties. Mid-range PSUs come with a 5-year warranty. High end PSUs come with 10 or 12-year warranties. Check your Alienware's warranty. It probably doesn't cover any component after 5 years.
Although your PSU may continue to work for another 5 years, it could fail earlier. High end PSUs with 10-year warranties use better designs and better components, e,g 105°C capacitors instead of 85°C versions.
According to the Tech Reviewer article below, the recommended power supply for a mid-range system like yours is 750W (their actual max power consumption figure is 588W). Add another 20W for your hard disks and you should still be OK with an 800W PSU, provided it's a good quality Gold unit.
Most of the time your computer will draw considerably less power, e,g 100W when idle.
Power Supply for RTX 4070 Ti GPU and Mid-Tier Components​
Mid-Tier ComponentsPeak Power Consumption
RTX 4070 Ti GPU285 watts
Mid-Tier CPU (e.g., Intel Core i5 13600K)181 watts
Motherboard80 watts
2 M.2 or 2.5" SSDs18 watts
2 Case Fans (120 mm)12 watts
2 CPU Fans (120 mm)12 watts
Total Estimate:588 watts
Recommended Power Supply Wattage:750 watts
https://www.techreviewer.com/best-tech/nvidia-rtx-4070-ti-gpu-power-supply/
Eximo
Ambassador
Dell/Alienware typically uses Greatwall which is a decent PSU manufacturer.
If they have put in a retail motherboard, then the PSU conforms to the ATX standard. Still Dell tends to do bare minimum viability for a lot of its setups, so the upgraded components may still be over stressing the PSU.
You have mismatched ram.
Your ram is running at the minimum default speed.
You may have to add voltage to the ram to get speed or stability.
Run memtest86+
It boots from a usb stick and does not use windows.
You can download it here:
If you can run a full pass with NO errors, your ram should be ok.
Running several more passes will sometimes uncover an issue, but it takes more time.
Probably not worth it unless you really suspect a ram issue.
TorQueMoD
96
Run memtest86+
How can I have mismatched RAM when I bought two kits of the same RAM? I think maybe you're misunderstanding and thinking I'm still running the Alienware ram. The only component left over from the Alienware is my PSU at this point. I will run the diagnostic though, thank you for the link :)
TorQueMoD
96
So I opened the case, and there's nothing I can see on the PSU that would let me know what the wattage or manufacturer is, so I'm guessing the label is underneath or on the side that is covered by the Case's separator. I can't be bothered to pull it out right now. If it comes down to it I will, but I'd rather go through other options first. I can't recall exactly, but I remember when I saw the PSU and the Mobo, I was impressed that they weren't cheap crap knowing that Dell bought Alienware.
If the system were underpowered, would it result in frame drops like this?
I have definitely been leaning towards thinking the issue is the GPU since it's right around 1 year old at this point. Sadly, I do not have the old one because I installed it in a friend's system. I do have a really old GPU - A GT-710 that I could plug in if it came down to it.
Aside from running something like Furmark or a benchmarking suite like the Unigine ones, do you guys know of a way to test the stability of a GPU? The part that confuses me is I don't seem to be having any frame rate issues when running Dead By Daylight, so that makes me think it might not be the GPU? Either that or DBD just isn't taxing enough to cause problems.
I might be wrong about the timeline of these components now that I think about it. Maybe it hasn't been happening for more than a year because I swear my GPU is less than 1 year old. Either way, it's been bugging me for a while, and I would have assumed if it was a software issue, re-installing Windows would have fixed that. Hmmm...
TorQueMoD
96
I looked through my receipts. Apparently, I upgraded the case, mobo, and CPU on Nov 7th, 2023, and my GPU was on May 12th, 2023. I feel like the issues started happening around 3 - 5 months after getting the GPU, so that would be around August - October of last year which is likely why I was thinking the GPU wasn't a year old yet.
Ram is sold in kits for a reason.
A motherboard must manage all the ram using the same specs of voltage, cas and speed.
The internal workings are designed for the capacity of the kit.
Ram from the same vendor and part number can be made up of differing manufacturing components over time.
Some motherboards, can be very sensitive to this.
This is more difficult when more sticks are involved.
Ram must be matched for proper operation.
From your cpu-z link, the ram is operating at 1046.1 In dual mode, that is 2123 or essentially stock speed.
Not the faster speed written on the sticks.
That may not account for your problem, but a slower than necessary cpu is part of it.
Misgar
Respectable
Mar 2, 2023
1,609
420
2,090
By the sound of it, the system worked OK for 3 to 5 months with the new GPU. Did the issues start after installing an update for Unreal Engine 5? Windows Updates have been known to "break" things too.
Are you using the default driver installed by Windows for your Zotac RTX 4070ti GPU? Are you running any GPU Core or Memory overclocks using Overdrive?
I couldn't understand why my 3-year old laptop was stuttering when playing back 4K H.265 GoPro videos. When I checked the video driver I discovered the date was 2019. After downloading and insatlling the latest driver, 4K videos play back smoothly.
