I need help for my first built
CPU - FX 8350 4Ghz AM3+ http://www.newegg.com/Product/Product.aspx?Item=N82E16819113284 (Definately should overclock with this)
GPU - 2x r9 280x Crossfire Mode http://www.newegg.com/Product/Product.aspx?Item=N82E16814202045
MOBO - ASUS Crosshair V Formula - http://www.newegg.com/Product/Product.aspx?Item=N82E16813131876
RAM - 2x8gb Corsair Vengeance 16 gb ram- http://www.newegg.com/Product/Product.aspx?Item=N82E16820233299
PSU - 1200 watt Corsair http://www.newegg.com/Product/Product.aspx?Item=N82E16817139039
Optical Drive - http://www.newegg.com/Product/Product.aspx?Item=N82E16827136250
Hard Drive - 2tb WD http://www.newegg.com/Product/Product.aspx?Item=N82E16822136579
Solid State drive - 256 GB http://www.newegg.com/Product/Product.aspx?Item=9SIA2W00YW3571
OS - Windows 7 http://www.newegg.com/Product/Product.aspx?Item=N82E16832116992
Case - http://www.newegg.com/Product/Product.aspx?Item=N82E16811146067
CPU Cooler - http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
This totally adds up to around 2150 Dollars. With the remaining money you can buy your monitor(s).
You can have mulimonitor display if u want because of the crossfire :)
Tell me if i left anything out
what is the best headset and speakers and enthernet card
