I need Help! huge virus
Utkarsh Mahajan
774
i have got problems with my cousin brother's pc he had removed and kept his pc because of house shifting to his new house so after 4-5 months he started pc the pc and it was a bit slow and he downloaded some shit virus softwares to speed up, etc. and from that time he has a lot of problems like screen resolution changes on startup, mouse cursor always blinking and other performance issues so he came to me and told it so i just used adw cleaner and malware bytes on his pc it removed nearly 700 viruses, trojans, malware, etc. but then too the screen resolution changes and the mouse cursor blinks all the way. can anyone tell me a solution to this.even i uninstalled alot of programs which are like suspicious but the software which was not able to remove was offerblvd even with some softwares whenever i try to do it the pc used to shutdown.
Help please.
Mtia
SkylerJacobs
685
And his reasoning as to why he does not want to do a fresh OS install?
Once you have that many viruses on a computer, you need to format the hard drive and re-install Windows. The damage done to drivers and system files cannot be fixed.
If you have the original Windows CD/DVD, boot from it, and format every hard drive that is in the system. Then install Windows on the C: drive.
If you do not have the original Windows CD/DVD, you are going to need to buy one or get the manufacturer of your computer to send you one. Expect them to want to charge a fee to replace the Windows installation CDs or DVDs.
Utkarsh Mahajan
774
he has a slow internet he don't wanna download anything again and he don't even have a backup. and at this place they take 10-15$ to make a clean install even having a copy of windows and they don't even install a geniune version here so only i install and give him.the genuine one which he has. :( in india thats the problem. they sell pirate copies more than genuine copies.
SkylerJacobs
685
You do not need to contact a manufacturer or pay a fee to get a windows installation disk. You can easily find a download online, and make a disk yourself.
SkylerJacobs
685
Then he will have to live with viruses on the computer for the rest of its life. Sorry to say, but that is the reality of the situation.
You can format the drives yourself and install the OS yourself. Its quite easy. A bit time consuming, but easy.
Karadjgne
Ambassador
Run the virus checker and malwarebytes again. Make sure you hit the box in settings that checks for root kits, MBR. Use Cleaner from piriform.com and run it through registry several times until there is nothing left. Also clean out any and all temp folders/files. Open up my computer and run through C drive and check everything. If any folder looks suspicious, investigate it throughly. Google anything you are unsure of.
With over 700 problems, guaranteed your software missed something. No virus scanner is infallible, they do miss some sometimes, use a different one.
If after all that, you still have problems, its more than likely the pc is clean, but one or more of those viruses has corrupted data somewhere usually in Windows, so you'll have to use the windows restore from the boot directory which will reset your key system files back to original, repairing the damage caused by the viruses.
Lotta work, but it beats having to do a full reinstal/format which is the only other way I can think of to repair the damage.
I would not suggest pirating Windows. Which sounds to me like you just did.
SkylerJacobs
685
I never in any way suggested pirating Windows, nor would i ever. Microsoft themselves provides direct downloads. Anybody can make a windows installation disk, so why on earth would you pay to have one sent to you.. A product key on the other hand, is where the cost comes into play.
Ooh, for windows 7 it seems microsoft has made it to where you must provide a product key now in order to create Windows 7 installation media.
Note: OEM keys will not work.
http://www.microsoft.com/en-us/software-recovery
As for Windows 8.1, you can easily create installation media.
http://windows.microsoft.com/en-us/windows-8/create-reset-refresh-media
