[SOLVED] I need help i have got a list with components i want to buy but i am not sure if they fit in the case
Sk1eZ
19
this is the list
NZXT H510i PC Gehäuse ASUS GeForce RTX™ 2080Ti
AMD Ryzen™ 9 3950X Prozessor ASUS ROG Strix X570 F Mainboard
CORSAIR Vengeance RGB PRO 16 GB CORSAIR CX750 V2 Netzteile 750 Watt
SAMSUNG 970 EVO M.2, 500 GB
SEAGATE Barracuda, 1TB, HDD,3,5 Zoll
NZXT KRAKEN X62 CPU
Its on german sry
They'll fit, but your choice of parts pushes the limit of what NZXT's H500 series can handle.
They are nice cases, but the focus of such a case is aesthetics. Thermal performance, it's 3rd banana.
I'm assuming the Kraken X62 is intended for the 3950X:
-2080Ti will thermal throttle in that case under load
-if you instead cool the 2080Ti on the AIO with the aid of a Kraken G12, then the 3950X will thermal throttle under load. The stock cooler isn't good enough for it.
You'll need to make a compromise somewhere.
If you want to stick to NZXT's style, there is the H700 series, which is the company's answer to the thermal performance of the other H models by basically brute forcing lower temps with more fan support.
ty bro but i already ordered everthing XD
so they all will fit together and everything will work well?
bc i was on pc part picker and i had like three notes saying this
  • Note: The Asus ROG Strix X570-F Gaming ATX AM4 Motherboard has an additional 4-pin ATX power connector but the Corsair CX (2017) 750 W 80+ Bronze Certified ATX Power Supply does not. This connector is used to supply additional 12V current to the motherboard. While the system will likely still run without it, higher current demands such as extreme overclocking or large video card current draws may require it.
  • Note: The NZXT Kraken X62 Liquid CPU Cooler may require a separately available mounting adapter to fit the Asus ROG Strix X570-F Gaming ATX AM4 Motherboard
  • Note: Some physical dimension restrictions cannot (yet) be automatically checked, such as cpu cooler / RAM clearance with modules using tall heat spreaders.
That's a bummer.
I already gave you the heads up on the temps, so you know what to expect once you put it all together...
Those notes:
1)I would have to point you towards Buildzoid's channel for that one: https://www.youtube(dot)com/watch?v=bqHd_tFqvj0
He goes pretty in depth on mobos.
From what I remember about X570, most of them are over-specced for Ryzen 3000. You may not have any issues with the lack of the 4 pin.
2)Has to do with the packaging. It's an older cooler, so you might get one that doesn't have the AM4 mounting kit. If it doesn't, you simply contact NZXT and they'll send you one.
3)Ignore. It always says that.
That's a bummer.
Those notes:
ty bro should i just try to cancel the case and get a h700? or should i just stick with this
hi guys i rly need a quick answer if possible i wanted to know if my psu and other parts fit together and will i have any trouble with em
NZXT H700 PC Gehäuse ASUS GeForce RTX™ 2080Ti AMD Ryzen™ 9 3950X Prozessor ASUS ROG Strix X570 F Mainboard CORSAIR Vengeance RGB PRO 16 GB CORSAIR CX750 V2 Netzteile 750 Watt
NZXT KRAKEN X62 CPU
Most important is the psu bc i am not sure if i should change it or stay on this one
NZXT H710 PC Gehäuse
,ASUS GeForce RTX 2080 Ti ROG Strix Gaming OC 11GB
,Ryzen 9 3950x
,ASUS ROG Strix X570 F Gaming Mainboard
,CORSAIR Vengeance RGB PRO Arbeitsspeicher 16 GB DDR4
,CORSAIR CX750 V2 Netzteile
,SAMSUNG 970 EVO Plus NVMe M.2, 500 GB, SSD, intern
,SEAGATE Barracuda, 1 TB, HDD, 3,5 Zoll, intern
,NZXT RL-KRX62-02 KRAKEN X62 CPU Wasserkühler
,ASUS PG279QE 27 Zoll WQHD Gaming Monitor (4 ms Reaktionszeit, 165 Hz)
HI guys just wanted to hear the opinion on my components and monitor :) ty
