A alens2003 Sep 17, 2018 1 0 10 Sep 17, 2018 #1 So i have in my pc 2x2gb ddr2 400mhz each and i want to put in 2 one gb rams each 1066 mhz will it work?
Solution ScrewySqrl Sep 17, 2018 assuming this is all DDR2, it will work, but it will slow all the ram down to that 400 speed. Its not a good idea. the 1066 sounds more like DDR3, which wouldn't be compatible
Peter Martin Splendid Oct 9, 2014 2,967 2 21,615 Sep 17, 2018 #2 no idea because you never told us the specifications of your PC, Make, Model, CPU, GPU, PSU, RAM, etc.. Upvote 1 Downvote
ScrewySqrl Champion Aug 2, 2010 11,199 232 53,540 Sep 17, 2018 Solution #3 assuming this is all DDR2, it will work, but it will slow all the ram down to that 400 speed. Its not a good idea. the 1066 sounds more like DDR3, which wouldn't be compatible Upvote 0 Downvote Solution
