B bonez23 Honorable Aug 24, 2015 42 0 10,530 Oct 4, 2015 #1 What is the difference between these two? APC Back-UPS 1100VA, 230V, AVR, Universal and IEC Sockets = BX1100LI-MShttp:// APC Back-UPS 1100VA, AVR, 230V, ASEAN = BX1100CI-MShttp:// The BX1100LI-MS model is a lot cheaper and I don't know why. Can you enlighten me on this please. Thanks in advance
rgd1101 Don't Moderator Nov 7, 2011 74,855 4,242 176,290 Oct 4, 2015 #2 There a few different in the technical spec tab Upvote 0 Downvote
B bonez23 Honorable Aug 24, 2015 42 0 10,530 Oct 4, 2015 #3 rgd1101 : There a few different in the technical spec tab Which one would you prefer if you are to buy one of them? Upvote 0 Downvote
rgd1101 Don't Moderator Nov 7, 2011 74,855 4,242 176,290 Oct 4, 2015 #4 That one with more watts. How much watts do your system draw? Upvote 0 Downvote
B bonez23 Honorable Aug 24, 2015 42 0 10,530 Oct 4, 2015 #5 rgd1101 : That one with more watts. How much watts do your system draw? Not much. I don't even have a GPU as I'm using an APU for my processor. I use it mainly for work so I was hoping I could get whichever is cheaper, but at the same time, the best quality Upvote 0 Downvote
