I need help my ryzen 2200g will only output 480p
Apr 4, 2018
5
I've been in contact with AMD for the past few days on problems that I've been having but they can't seem to be able to help me. Everytime I download the drivers for my APU through AMD or msi after a restart it'll just default to 480p or sometimes it just won't recognize a signal from the APU. it also always says that I'm using a DVI connection instead of HDMI. On top of this whenever I download the drivers and restart I can't go into bios. Ive tried re-downloading windows and it still persists. It will work if I turn off my power supply and wait about 20min but it still only thinks that it's a DVI connection. I'm using a msi b350 pc mate, 8 gigs of g.skill NT series(with two gigs allocated to the Apu also the integrated graphics are enabled in the Bios) a Corsair 450 watt power supply, a WD blue hard drive, and the ryzen 2200g. I just really need help on this.
It is a TV that worked with my old system that had a GTX 1050 that I had to get rid of. But it's an insigina tv that I got like three years ago I don't really know what the model number is
The model number can be found on a sticker in the back. The GTX 1050 may have been able to detect it properly, but a TV isn't always like a real monitor. Does your TV have an HDMI port configured as as PC monitor? Is the HDMI port configured correctly to use the TV as a monitor? If not, then 480p is the default.
yes that is the tv, I usually connect it to HDMI 2 but I have tried one and several different HDMI cables the settings wouldn't make a difference there's no game mode or whatever but it stays one standard, and yes I always turn the TV on and select the HDMI connection first before powering on my PC
