B brett.denooijer Prominent Nov 1, 2017 80 0 630 Dec 26, 2017 #1 Does anyone know what settings I would have to run to get 60 fps on games with a a10 7860k and 1050ti with 8gb of ram ?
Solution vrumor Dec 26, 2017 The lowest graphics settings for most games. Some older and indie games will run fine on higher settings, but not AAA games.
vrumor Judicious Jan 17, 2012 7,747 1 35,015 Dec 26, 2017 Solution #2 The lowest graphics settings for most games. Some older and indie games will run fine on higher settings, but not AAA games. Upvote 0 Downvote Solution
maxalge Champion Ambassador May 31, 2012 13,371 4 56,960 Dec 26, 2017 #3 brett.denooijer : Does anyone know what settings I would have to run to get 60 fps on games with a a10 7860k and 1050ti with 8gb of ram ? resolution? for 1080p start at medium and crank up settings as performance dictates a lot of games it will be impossible for you to get 60 fps regardless of settings because of the a10 Upvote 0 Downvote
C Calvin7 Titan Feb 19, 2013 11,722 336 76,490 Dec 26, 2017 #4 A10-7850K Supported memory: DDR3-2133, (OC) DDR3-2400 Upvote 0 Downvote
