[SOLVED] i need help to build my pc
Dec 5, 2020
I am planning to build a computer and although I already have in mind most of the components, I cannot decide on the power source and I am not sure of the compatibility of the hadware so I leave you a list of what I have in mind to help me to check the compatibility of everything and to find the power source and the video card; And if you help me see what is missing, I would appreciate it
MOTHERBOARD https://www.gigabyte.com/Motherboard/Z490-AORUS-ULTRA-rev-1x#kf
Z490 AORUS ULTRA (rev. 1.x)
PROCESADOR https://www.intel.com/content/www/us/en/products/processors/core/i9-processors/i9-10900k.html
Intel® Core™ I9-10900K Processor
RAM https://www.corsair.com/us/en/Categ...Vengeance-PRO-RGB-Black/p/CMW128GX4M4X4000C18
VENGEANCE® RGB PRO 128GB (4 x 32GB) DDR4 DRAM 4000MHz C18 Memory Kit — Black
CHASIS https://www.corsair.com/us/en/Categories/Products/Cases/Mid-Tower-ATX-Cases/Carbide-Series-SPEC-DELTA-RGB-Tempered-Glass-Mid-Tower-ATX-Gaming-Case-%E2%80%94-Black/p/CC-9011166-WW#tab-tech-specs
Carbide Series SPEC-DELTA RGB Tempered Glass Mid-Tower ATX Gaming Case — Black
RAM...
Please don't buy that case it's really bad. There's tons of better options. In that price range I'd suggest the Lian Li Lancool 215. You don't really need that fast RAM with Intel btw, 3200mhz is fine. And why Intel? Is it because of lack of stock? Because for gaming Ryzen is superior now
PSU depends on your GPU. I'd suggest the 3060 Ti for 1080p high refresh at Ultra and 1440p high refresh at like medium. I wouldn't really suggest the 3070 unless 3060 Ti is completely out of stock, because you're better off witha. 3080 at that point.
For PSU, with a 3060 Ti I'd suggest Corsair RM650x. With a 3080 I'd suggest RM850x
