I need help to choose a motherboard
aznphatty
9
Which motherboard is better
ASUS P7P55D-E Pro
- I read that thre is a high pitch noise coming from this board. Is it really that bad?
GIGABYTE GA-P55A-UD4P
- If I want to use full power of usb3 then the pci-e slot is down to 8x
I really don't plan to SLI but the option to SLI is good if I do decide to do it. I might just hold off on usb3 altogether and wait when the tech gets better, and I can save on boards that don't have usb3. Are there other board that you recommend? Under $200 would be great.
If it helps I plan to get the i7 870 and I have the gtx 460 1gb.
