Question I need help with an old Oculus CV1 ?
jacyslayer
5
i need help with my old Oculus CV1. It's been siting in my barn for years but i cleaned it like it was brand new.
I plugged everything in, it said everything was working, the head set tracking and controls and sensors all worked but there is just a black screen.
I can see the orange light come on and go off if you cover it. I've got an NVIDIA RTX 3050 on Windows 11.
i bought a DP to HDMI adapter because the card only has 1 HDMI port and 3 display adapters.
Anyways it could be the headset or it could be the cord that's all mangled up from years of twisting maybe if i buy a new oculus headset cord i could get it working?
Geforce Experience says NVIDIA RTX 3050 doesn't support VR, it says GTX 970 or higher. but i got the small RTX 3050 'cos I have a have a tiny PC.
All i really want to do is use the Oculus CV1 controllers without the headset some way some how really will these programs work? auto_oculus_touch_v0.1.7 vJoy AutoHotkey_2.0.17?
OS Name Microsoft Windows 11 Enterprise
Version 10.0.22631 Build 22631
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name SLAYER
System Manufacturer HP
System Model Victus by HP 15L Gaming Desktop TG02-0xxx
System Type x64-based PC
System SKU 49N24AV
Processor 12th Gen Intel(R) Core(TM) i5-12400, 2500 Mhz, 6 Core(s), 12 Logical Processor(s)
BIOS Version/Date AMI F.24, 1/4/2024
SMBIOS Version 3.4
Embedded Controller Version 147.19
BIOS Mode UEFI
BaseBoard Manufacturer HP
BaseBoard Product 89B5
BaseBoard Version A (SMVB)
Platform Role Desktop
Secure Boot State On
PCR7 Configuration Elevation Required to View
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume3
Locale United States
Hardware Abstraction Layer Version = "10.0.22621.2506"
User Name SLAYER\SLAYERJACY
Time Zone Pacific Daylight Time
Installed Physical Memory (RAM) 32.0 GB
Total Physical Memory 31.7 GB
Available Physical Memory 23.2 GB
Total Virtual Memory 36.4 GB
Available Virtual Memory 27.0 GB
Page File Space 4.75 GB
Page File C:\pagefile.sys
Kernel DMA Protection On
Virtualization-based security Not enabled
Windows Defender Application Control policy Enforced
Windows Defender Application Control user mode policy Off
Device Encryption Support Elevation Required to View
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Second Level Address Translation Extensions Yes
Hyper-V - Virtualization Enabled in Firmware No
Hyper-V - Data Execution Protection Yes
SteamVR Version: 2.6.2 (1716600417)
SteamVR Date: 2024-05-24
Steam: Public
Steam Branch:
Steam AppID: 250820
Tracking: oculus
OS: Windows 11
OS Version: 10.0.0.22631
Direct Mode Vendor: NVIDIA
Direct Mode Version: 555.99
Admin: No
AsyncReprojection: Enabled
Performance drops: 54/1 7/2 1/3 0/4 3349/3516
Display Mode: Direct Mode
</Report>
<Displays>
DeviceName: \\.\DISPLAY1
DeviceDirectMode: No
DevicePrimary: Yes
DeviceRect: 3840x2160 @ (0, 0)
DeviceString: NVIDIA GeForce RTX 3050
DeviceID: PCI\VEN_10DE&DEV_2507&SUBSYS_8E991462&REV_A1
DeviceKey: \Registry\Machine\System\CurrentControlSet\Control\Video\{1F638F21-08BC-11EF-B870-F0A654ECC8CC}\0000
DeviceMonitorCount: 1
Monitor 0 DeviceName: \\.\DISPLAY1\Monitor0
Monitor 0 DeviceString: Generic PnP Monitor
Monitor 0 DeviceID: MONITOR\TCL0000\{4d36e96e-e325-11ce-bfc1-08002be10318}\0002
Monitor 0 DeviceKey: \Registry\Machine\System\CurrentControlSet\Control\Class\{4d36e96e-e325-11ce-bfc1-08002be10318}\0002
</Displays>
<Devices>
Device 1 - WMHD31516008YB Headset Oculus Rift CV1 Oculus
Device Path: /devices/oculus/WMHD31516008YB
Best Alias: /user/head
Firmware:
Hardware Revision: 14
Hardware Id: 0x0000000e
Camera Firmware: Version not available.
VSync to Photons: 0.0111114
Display Frequency: 89.998
User IPD (m): 0.0702103
Current Universe ID: 9277627169237578379
Previous Universe ID: 0
Device 2 - WMHD31516008YB_Camera0 Base Station Oculus Rift CV1 (Camera0) Oculus
Device Path: /devices/oculus/WMHD31516008YB_Camera0
Firmware:
Radio Version: Feature not configured for this device.
Channel:
FOV Left: 50
FOV Right: 50
FOV Top: 35
FOV Bottom: 35
Range Minimum (m): 0.4
Range Maximum (m): 2.5
Device 3 - WMHD31516008YB_Camera1 Base Station Oculus Rift CV1 (Camera1) Oculus
Device Path: /devices/oculus/WMHD31516008YB_Camera1
Firmware:
Channel:
FOV Left: 50
FOV Right: 50
FOV Top: 35
FOV Bottom: 35
Device 4 - WMHD31516008YB_Controller_Left Controller Oculus Rift CV1 (Left Controller) Oculus
Device Path: /devices/oculus/WMHD31516008YB_Controller_Left
Best Alias: /user/hand/left
Firmware:
Attached Device ID:
Supported Buttons: 30064771207
Axis 0 Type: 2
Axis 1 Type: 3
Axis 2 Type: 3
Axis 3 Type: 0
Axis 4 Type: 0
Connected Dongle: Version: Unknown Version
Device 5 - WMHD31516008YB_Controller_Right Controller Oculus Rift CV1 (Right Controller) Oculus
Device Path: /devices/oculus/WMHD31516008YB_Controller_Right
Best Alias: /user/hand/right
Firmware:
Attached Device ID:
Axis 0 Type: 2
Axis 1 Type: 3
Axis 2 Type: 3
Axis 3 Type: 0
Axis 4 Type: 0
Device 17 - 030000005e040000ff02000000007801 Controller XInput Controller
Device Path: /devices/gamepad/030000005e040000ff0200000000780
Best Alias: /user/gamepad
Firmware:
Hardware Revision:
Attached Device ID:
Supported Buttons: 0
Axis 0 Type: 0
Axis 1 Type: 0
Axis 2 Type: 0
Axis 3 Type: 0
Axis 4 Type: 0
</Devices>
<USB>
[HostController] USB xHCI Compliant Host Controller
Manufacturer: Generic USB xHCI Host Controller, Provider: Microsoft, 5/21/2024, 10.0.22621.3672
Root Hub
[Port1]
[Port2]: Generic USB Hub (VID:2833 PID:2031)
[Port1]: USB Composite Device (VID:2833 PID:0031), Oculus VR, Inc., Rift, WMHD31516008YB
[Port2]: USB Composite Device (VID:2833 PID:0330), Oculus, Rift Audio, WMHD31516008Y
[Port3]
[Port4]
[Port3]
[Port4]
[Port5]
[Port6]
[Port7]
[Port8]
[Port9]
[Port10]: Generic USB Hub (VID:0BDA PID:5411)
[Port1]: Generic USB Hub (VID:0BDA PID:5411)
[Port1]
[Port2]
[Port3]
[Port4]
[Port2]: Xbox Gaming Device (VID:3537 PID:1010), Guangzhou Chicken Run Network Technology Co., Ltd., GameSir-G7 SE Controller for Xbox, 00005E4D1AB077CD
[Port3]: USB Composite Device (VID:1EA7 PID:0066), 2.4G Mouse
[Port4]: USB Composite Device (VID:03F0 PID:2641), MOSART Semi., HP Wireless Keyboard and Mouse
[Port11]
[Port12]
[Port13]
[Port14]: Realtek Bluetooth 5 Adapter (VID:0BDA PID:B00C)
[Port15]
[Port16]
[Port17]
[Port18]
[Port19]: Generic SuperSpeed USB Hub (VID:0BDA PID:0411)
[Port1]: Generic SuperSpeed USB Hub (VID:0BDA PID:0411)
[Port1]
[Port2]
[Port3]: USB Composite Device (VID:2833 PID:0211), Oculus VR, Rift Sensor, WMTD3051601PKC
[Port4]: USB Composite Device (VID:2833 PID:0211), Oculus VR, Rift Sensor, WMTD3051601Q6A
[Port2]
[Port3]
[Port4]
[Port20]: Generic SuperSpeed USB Hub (VID:2833 PID:3031)
[Port1]
[Port2]
[Port3]
[Port4]
[Port21]
[Port22]
[Port23]
[Port24]
[Port25]: USB Attached SCSI (UAS) Mass Storage Device (VID:0634 PID:5603), Micron, CT1000X9PROSSD9, 2322E8C03557
[Port26]
</USB>
<Logs>
=== vrserver.txt - C:/Program Files (x86)/Steam/logs
Thu Jun 20 2024 15:58:18.291 [Info] - //==============================================================================================
Thu Jun 20 2024 15:58:18.291 [Info] - ================================================================================================
Thu Jun 20 2024 15:58:18.291 [Info] - vrserver.exe 2.6.2 startup with PID=14424, config=C:\Program Files (x86)\Steam\config, runtime=C:\Program Files (x86)\Steam\steamapps\common\SteamVR, arch=win64
Thu Jun 20 2024 15:58:18.291 [Info] - [vrserver] watchdogs enabled
Thu Jun 20 2024 15:58:18.293 [Info] - CSharedResourceNamespaceServer starting up
Thu Jun 20 2024 15:58:18.293 [Info] - Set thread FFFFFFFFFFFFFFFE priority to: 1
Thu Jun 20 2024 15:58:18.293 [Info] - WaitNamedPipe SteamVR_Namespace failed because no one is listening at that name (Error 0x07160fc0)
Thu Jun 20 2024 15:58:18.293 [Error] - CSharedResourceNamespaceClient::Init(): failed connect
Thu Jun 20 2024 15:58:18.293 [Warning] - CSharedResourceNamespaceClient::Init(): still waiting for vrserver to reply with namespace data
Thu Jun 20 2024 15:58:18.293 [Info] - Set thread FFFFFFFFFFFFFFFE priority to: -15
Thu Jun 20 2024 15:58:18.365 [Info] - Connecting client (SteamVR_Namespace) app container status: 1
Thu Jun 20 2024 15:58:18.365 [Info] - CSharedResourceNamespaceServer sent namespace data: 14424
Thu Jun 20 2024 15:58:18.394 [Info] - Client (SteamVR_Namespace) app container state: 1
Thu Jun 20 2024 15:58:18.397 [Info] - Connecting client (SteamVR_Namespace) app container status: 1
Thu Jun 20 2024 15:58:18.397 [Info] - CSharedResourceNamespaceServer sent namespace data: 14424
Thu Jun 20 2024 15:58:18.397 [Info] - CSharedResourceNamespaceClient::Init(): received namespace data 14424
Thu Jun 20 2024 15:58:18.397 [Info] - Self queried namespace: 14424
Thu Jun 20 2024 15:58:18.397 [Info] - [Init] VR server 2.6.2 (v1716600417) starting up with config=C:\Program Files (x86)\Steam\config
Thu Jun 20 2024 15:58:18.397 [Info] - [Init] VRServer will wait for VRMonitor before exiting
Thu Jun 20 2024 15:58:18.400 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\htc\resources\settings\default.vrsettings
Thu Jun 20 2024 15:58:18.400 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\lighthouse\resources\settings\default.vrsettings
Thu Jun 20 2024 15:58:18.400 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\null\resources\settings\default.vrsettings
Thu Jun 20 2024 15:58:18.400 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\SteamVR\drivers\vrlink\resources\settings\default.vrsettings
Thu Jun 20 2024 15:58:18.400 [Info] - [Settings] Load Default Json Settings from C:\Program Files (x86)\Steam\steamapps\common\iVRy\resources\settings\default.vrsettings
Two things:
1) "i need help with my old Oculus CV1. It's been siting in my barn for years but i cleaned it like it was brand new."
If the Oculus was exposed to the elements especially heat/cold/humidity then there could be problems other than just the physical dirt and grime you cleaned off. Cable twists and kinks may or may not be a problem.
2) "All i really want to do is use the Oculus CV1 controllers without the headset some way some how really will these programs work? auto_oculus_touch_v0.1.7 vJoy AutoHotkey_2.0.17?"
As I understand your post just using or repurposing the controllers is likely to require some coding.
Google words and phrases such as "How to program oculus cv1 controllers reddit".
Take a look at the search results then revise the search criteria as necessary to narrow down more to the specifics regarding how you would like to use (reuse) the Oculus CV1 controllers.
And add some details to your post regarding the plan and requirements to reuse the controllers.
Lastly:
"Geforce Experience says NVIDIA RTX 3050 doesn't support VR, it says GTX 970 or higher. but i got the small RTX 3050 'cos I have a have a tiny PC."
Not sure about the full meaning - can you add some specific details to explain.
Two things:
Lastly:
Under geforce settings it says "does not meet the recommended spec for virtual reality" then it says: "desktop gtx 970 or higher". i don't get it. I have an rtx 3050 which is way higher then a gtx 970.
Take a closer look at the recommended specs for virtual reality.
Search/Google words and phrasing such as "recommended GPU specs for VR".
After reading etc. revise the search criteria as necessary to match your computer environment and specs.
Here is a link (not a product recommendation or endorsement) listing reasons regarding GPUs for VR.
https://pimax.com/blogs/blogs/best-...orce,while still having fantastic performance.
There are other similar links to be found - look for links applicable to your components and VR requirements.
