I need help with my 1440x900p Monitors Resolutions?
Oliver_16
126
So I have a 1440x900p monitor. It usually have 900p reolution and below that. But today I hooked it up and it only list 4 resolutions and the highest it can go to is 1280x720p.
The monitor uses a VGA connection and I have it set to my GTX 1060 6gb with a VGA Female to HDMI Male Connector.
This never happened before and I am stuck on trying to figure out how to get the resolution to native 900p.
I have updated the Drivers of my GTX 1060 to the current drivers available currently 3/1/2018.
nvm, I found the solution after many hours.
The problem came from the VGA Female to HDMI Male adapter that I was using, For some reason it only let the computer have the 720p resolution as the highest one. I switched it with another one and now I am able to get all the way to 1080p on this old 900p monitor. :)
