I Need Help with My Computer Build
Inflammist
So basically, I have decided to take a step up in my computer. I have decided that I will build one! The task is quite daunting, and the only trouble I am having is knowing what Power Supply to get. I have no Idea about wattage and volts and all that stuff. Can you recommend what kind of power supply I should get? Will I need to get a CPU fan, or does it come with it? Any suggestions for the build? Here are the specs:
CPU:
http://www.amazon.com/dp/B00CPLGFM4/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=1XYEIPDDDHQYU&coliid=I1TRZZPO4COO1M
Motherboard:
http://www.amazon.com/P8B75-M-CSM-Intel-Micro-Motherboard/dp/B007RIFMQA/ref=sr_1_4?s=electronics&ie=UTF8&qid=1391030666&sr=1-4&keywords=Asus+Motherboard
Ram:
http://www.amazon.com/dp/B008E3M4TU/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=1XYEIPDDDHQYU&coliid=I4JUW9L1N275N
Display:
http://www.amazon.com/VS207D-P-20-Inch-Screen-LED-Lit-Monitor/dp/B00B5Q6Y8U/ref=sr_1_5?ie=UTF8&qid=1391030944&sr=8-5&keywords=ASUS+monitor
Hard Drive:
http://www.amazon.com/dp/B00461G3MS/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=1XYEIPDDDHQYU&coliid=I1VFDRIHH16721
GPU:
http://www.amazon.com/dp/B008RIEOBS/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=1XYEIPDDDHQYU&coliid=I3QP6UBT91CNXG
Optical Drive:
http://www.amazon.com/dp/B00EUAFAF6/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=1XYEIPDDDHQYU&coliid=I1YCKS0FXRPPYX
Case:
http://www.amazon.com/Thermaltake-Black-Power-Supply-VL800P1W2N/dp/B007BDJ5SM/ref=sr_1_7?s=electronics&ie=UTF8&qid=1391031022&sr=1-7&keywords=Case+Computer
This includes my recommended power supply. Will get you MUCH better gaming performance, and much better CPU performance. Actually came in $25 under what yours added up to, is right at $540 with a power supply :)
CPU: AMD FX-4300 3.8GHz Quad-Core Processor ($104.99 @ SuperBiiz)
Motherboard: MSI 970A-G46 ATX AM3+ Motherboard ($59.99 @ Newegg)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory ($72.25 @ Newegg)
Storage: Seagate Barracuda 500GB 3.5" 7200RPM Internal Hard Drive ($44.80 @ Amazon)
Video Card: XFX Radeon HD 7850 2GB Video Card ($149.99 @ NCIX...
Video Card: XFX Radeon HD 7850 2GB Video Card ($149.99 @ NCIX US)
Case: NZXT Gamma Classic (Black) ATX Mid Tower Case ($34.99 @ Newegg)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply ($59.99 @ NCIX US)
Optical Drive: LG GH24NSB0 DVD/CD Writer ($14.99 @ Newegg)
Total: $541.99
(Generated by PCPartPicker 2014-01-29 17:09 EST-0500)
Oh, wow! Amazing! I think that you have just found the parts to my new rig! Thanks a bunch. This is probably better than what I would have been able to choose.
Although this is a great build, the original one included the monitor. Here there is no monitor. I don't already have a monitor, so I think that the build needs to come to about $400.
Sorry about that, didn't catch the monitor. Drops a little bit in performance, but the 7770 GHz is still great for the money.
CPU: AMD Athlon II X4 750K 3.4GHz Quad-Core Processor ($79.99 @ Amazon)
Motherboard: Gigabyte GA-F2A55M-HD2 Micro ATX FM2 Motherboard ($49.99 @ Microcenter)
Memory: A-Data XPG V1.0 4GB (1 x 4GB) DDR3-1600 Memory ($32.99 @ Newegg)
Storage: Seagate Barracuda 500GB 3.5" 7200RPM Internal Hard Drive ($47.00 @ Amazon)
Video Card: Sapphire Radeon HD 7770 GHz Edition 1GB Video Card ($110.98 @ SuperBiiz)
Case: NZXT Gamma Classic (Black) ATX Mid Tower Case ($34.98 @ Best Buy)
Power Supply: Corsair Builder 430W 80+ Bronze Certified ATX Power Supply ($19.99 @ Microcenter)
Total: $390.91
(Generated by PCPartPicker 2014-02-03 14:14 EST-0500)
Do you think that you could find a build that includes a monitor? Sorry to rely on you like this, but I really have no idea what i'm doing when it comes to building computers.
No problem lol BenQ is a great brand for monitors, and 1080p is a good resolution. Should get decent graphics with this card at that resolution :) Should get you medium-high in everything, and some games at Ultra, depending on what FPS you want :) http://www.anandtech.com/show/5541/amd-radeon-hd-7750-radeon-hd-7770-ghz-edition-review/17
Monitor: BenQ GW2255 60Hz 21.5" Monitor ($104.99 @ NCIX US)
Total: $495.90
(Generated by PCPartPicker 2014-02-03 14:59 EST-0500)
AND came in $4 under budget 😛
Thanks, once again. I really appreciate it.
Sorry again, but will I need to buy a WiFi and sound card too?
