I need help with my ethernet adaptators (powerline)!
Zashypoo
50
Hello, I have a powerline in my apartment but problem is the neighbor also has a powerline, so my problem is that my neighbor has my good 50$ connection and I'm using his shit 5$ connection, I have trouble even loading this site.... I need help on how to secure my network and how to specifically pair two adaptators.
Best Regards, Zach
You need to read your manual-- they are all a bit different -- your adapters should have a software configuration program to prevent exactly this problem, but it depends on your specific adapters how to use it. Plug and pray only works if you are the only one around.
Alright Thanks, I guess I'll just buy a new one 🙁
