I need help with my new pc
Nexus Needs Help
Commendable
Aug 22, 2016
5
i've wanted to build a pc since i was 15 so i did some research and found parts that are compatible. So when i bought the parts and put the pc together it started beeping i've tried to fix this pc for so long but i gave up. Now i'm 16 (almost 17) and there are some pc games i want to play that my laptop can't handle. So i want to know if anyone can help me with my pc?
Parts i used:
AMD A4-7300
G.SKILL Ripjaws X Series 4GB (DDR3 1600)
GA-F2A88XM-D3HP (Motherboard)
500gb Hard Drive
Logisys CS370BK ((Case)Came with power supply but i switched it out with a evga 430 watt supply)
EVGA GeForce GT 610
That's a really bad system, but each to his own. 😀
Sounds like you've got a single stick of RAM in the pc, and it could potentially be in the wrong slot. If you know your motherboard model it's usually easy to look up the beep codes for it in the manual.
I see your RAM isn't on the supported list for that motherboard:
http://download.gigabyte.us/FileList/Memory/mb_memory_ga-f2a88xm-d3hp.pdf
F3-12800CL9S-4GBXL
RAM is RAM, so it should just work, but you never know.
F3-12800CL9S-4GBXL
