I need help with my PC build
slendey9x
6
I need help buying my new PC and I don't k ow if my list is good. I have a budget of 1,200 to build a PC. I originally was going to buy the Asus gr8 ii but than I figured I would just build it. My build is all on this link (btw I have two of those ram) please tell me what I should change and what to do to get a great gaming PC like the gr8. PS. I am new to this so I'm what I'm doing. https://photos.app.goo.gl/iyfLV9qYAgFmsB6l2
What about this? I kept only the essentials. It's cheaper and will give slightly lower performance, but not by a lot. The difference in the 1080 and 1070 Ti is not much. http://gpu.userbenchmark.com/Compare/Nvidia-GTX-1080-vs-Nvidia-GTX-1070-Ti/3603vs3943
CPU: Intel - Core i5-8400 2.8GHz 6-Core Processor ($199.89 @ B&H)
Motherboard: MSI - Z370-A PRO ATX LGA1151 Motherboard ($117.99 @ SuperBiiz)
Memory: G.Skill - Ripjaws V Series 8GB (2 x 4GB) DDR4-3200 Memory ($89.99 @ Newegg)
Storage: Samsung - 850 EVO-Series 250GB 2.5" Solid State Drive ($84.99 @ B&H)
Video Card: EVGA - GeForce GTX 1070 Ti...
There I added the rest of the components
Use https://pcpartpicker.com/list/ to add all your parts you want to it and then share the list here. It makes it easy for fitting the best parts in to a specific budget.
Then me or someone can try to build a better parts list for the same price if possible.
Ok I will but I'm just saying that all tose components added up to $1,999 on Amazon.
I'm not sure how it costs that much. Here's a $1500 build that's got better parts.
CPU: Intel - Core i5-8600K 3.6GHz 6-Core Processor ($295.99 @ B&H)
CPU Cooler: CRYORIG - R1 Ultimate 76.0 CFM CPU Cooler ($69.99 @ Newegg Marketplace)
Motherboard: Asus - TUF Z370 Pro Gaming ATX LGA1151 Motherboard ($129.99 @ Amazon)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory ($194.99 @ Amazon)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($41.89 @ SuperBiiz)
Video Card: Gigabyte - GeForce GTX 1080 8GB WINDFORCE OC 8G Video Card ($544.98 @ Newegg)
Case: Phanteks - Enthoo Pro M ATX Mid Tower Case ($85.98 @ Newegg)
Power Supply: SeaSonic - FOCUS Plus Gold 750W 80+ Gold Certified Fully-Modular ATX Power Supply ($79.90 @ Newegg)
Total: $1528.70
Generated by PCPartPicker 2017-11-30 23:17 EST-0500
Can this run better games, and what can it run
Also thanks so much you've been a big help
It has 2 extra cores on the CPU. So yes there will be games that rely more on the CPU that will run better on that system. It will run any game you want to play.
It depends on what your monitor's resolution is as to what kind of performance you will see.
Glad I could help.
Hey I saw the build and I really like it, ive been having trouble with my computer so it won't let me type so I'm using my phone right now but I was wondering if there was a way to reduce the price, I don't need monitors or anything like that rn, I just need the computer. Also if I keep one of those sad and remove the rest from that build, will it affect it, I can always add stuff later. I looked at ur build and I got it down to 1,600, can you please help me out with reducing the price. Also thanks you've been a big help.
Video Card: EVGA - GeForce GTX 1070 Ti 8GB SC GAMING ACX 3.0 Black Edition Video Card ($469.99 @ B&H)
Case: Phanteks - ECLIPSE P400 TEMPERED GLASS ATX Mid Tower Case ($64.99 @ Amazon)
Power Supply: SeaSonic - S12II 620W 80+ Bronze Certified ATX Power Supply ($48.99 @ SuperBiiz)
Total: $1076.83
Generated by PCPartPicker 2017-12-01 16:54 EST-0500
What does a little bit worst mean, is it a huge difference or do you think I can upgrade later by buying more parts.
