[SOLVED] I need help with my purchase of ram
samy111
41
I can't found on my country the vengeance led white that I have install on my pc (CMU16GX4M2C3200C16 , 2x16GB). I want add 2 more (to 32gb).
I found the Vengeance Pro RGB, whith similar
specifications but phisically its different (CMW16GX4M2C3200C16W) ¿I Can use this with my ram? Even the voltage is the same...
Thanks for advanced
Generally speaking, the rule of thumb is, if you can't find identical modules, then it's best to use such that have the same timings & voltage as the current (and both of the ones you've mentioned are compatible in that regards) so it should be perfectly fine.
Reactions: samy111
I appreciate your answer and help. Thank you very much
