i need help with new pc build
Sep 27, 2017
Hi!
i have the following parts for my pc. and wondering if theres something i must change. or add ? and is the wattage of the psu enough? Thanks!
NZXT S340 - case
ASUS ROG Strix B350-F Gaming, Socket-AM4 - motherboard
WD Desktop Blue 1TB 3.5" - hdd
Corsair TX550M, 550W PSU - PSU
AMD Ryzen 5 1500X Prosessor - CPU
Microsoft Windows 10 Home - os
ASUS GeForce GTX 1060 6GB DUAL OC - gpu
Corsair Vengeance LPX DDR4 3000MHz 8GB - RAM
I really appericate your answers, thanks!
Maybe add an SSD as the main drive for the OS and use the regular HD for games etc.
A 250GB M.2 SSD like a Samsumg 960 EVO M.2 NVME 250GB.
stian check my question here: http://www.tomshardware.co.uk/answers/id-3529588/build-post-display-built-years.html#xtor=EPR-8809
Basically, although my motherboard manufacturer's site (ASRock) said that it supports the type of CPU I bought (Ryzen 5 1600x), the BIOS it shipped with didn't support the model number of my Tyzen 5 1600x. If possible, check that the actual model number of your CPU is listed as supported by the mobo, not just the chip type. Or ask the seller if the BIOS it ships with supports your CPU model number.
