i need help with this build !
Matthew Sellers
i need to know if this http://www.newegg.com/Product/Product.aspx?Item=N82E16811353062 case
will fit the following parts
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.2384579 motherboard / processor
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202090
gpu
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
ram
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139028
power supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16822236070
hard drive
im used to building full towers and mid tower pc's . but on this occasion my friend wants me to build him something a little smaller . thus i am unsure of myself . could i get a secound opnion ?? please and thank you
-matt
Looks like your okay! If you look at the SPEC's for the Case - it's a mid-tower and looks like the MB is mounted 'horizontally' as opposed to Full Towers would be mounted vertically. Specs say:
Support full size high-end desktop components (full size ATX PSU, standard Mirco-ATX/ Mini-ITX MB, 3.5”/2.5” HDD/SSD)
So that covers most of the components except for the RAM (which is a 'no brainier') and the Video Card!
Specs for the case say: Support up to 340mm VGA card
Card MFG Says: Dimension 228(L)X109(W)X35(H) mm Size. 2 x slot
So that's covered!
The CPU comes with a cooler and that should be fine since the MB does mount in the horizontal.
So it looks like you're good to go!!
So that's covered!
