[SOLVED] I need help with upgrading my pc
arn19531
8
I have a considerably big upgrade in mind for my pc. After 6 years, I want to change my processor, RAM and MoB.
I already have the following hardwares:-
(The numbers in the bracket is the year the component was bought)
  1. AMD A10 7700k APU (2014)
  2. MSI A78M MS-7721 MoB (2014)
  3. Some DDR3 2X8gb Ram which worked really well upto this point (2019)
  4. Gigabyte RX 560 4gb OC (2019)
  5. Thermaltake 550 watt psu (2019)
I want to buy:-
  1. AMD Ryzen 3 2200G Quad-Core Processor With Radeon Vega 8 Graphics
  2. Gigabyte B450M S2H/ASRock B450M-HDV R4.0 AMD Motherboard
3.CORSAIR VENGEANCE LPX 8GB DDR4 3200MHZ RAM
Is this build going to support with all the aforementioned hardwares ?? Please note that I don't want to buy any costly hardware component as this is coming from my savings.
If there is anything I should add please let me know.
The budget is 260 usd.(approximately)
I second the R5 1600 AF. The board I chose supports Ryzen 3000, out of the box, so should have a larger bios chip, to handle future CPU support. Ram I chose due having used it in multiple rigs.
PCPartPicker Part List
Motherboard: ASRock B450M/AC Micro ATX AM4 Motherboard ($84.99 @ Newegg)
Memory: G.Skill Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200 Memory ($73.99 @ Newegg)
Custom: Ryzen 5 1600 AF ($85.00)
Total: $243.98
Generated by PCPartPicker 2020-03-26 12:02 EDT-0400
Ryzen 1600 AF $85
https://www.amazon.com/AMD-Processor-Wraith-Stealth-Cooler/dp/B07XTQZJ28
Motherboard/Memory $142.98
Motherboard: Gigabyte B450M DS3H Micro ATX AM4 Motherboard ($72.99 @ Newegg)
Memory: Team T-FORCE VULCAN Z 16 GB (2 x 8 GB) DDR4-3200 Memory ($69.99 @ Newegg)
Total: $142.98
Generated by PCPartPicker 2020-03-26 11:57 EDT-0400
Total. $227.98
These parts will easily outperform the 2200G, the 1600 AF performs almost identical to the Ryzen 2600.
Since your changing out the motherboard it will require a clean install of Windows & drivers so be sure to backup any important files before you do this.
Total: $243.98
Ryzen 1600 AF $85
Total: $142.98
Total. $227.98
Sadly I cannot find the ryzen 1600 and the memory in my country.
But the things I mentioned in my description are available. Will they comply??
