A Alienjorgito Reputable Jul 19, 2014 20 0 4,510 Dec 22, 2014 #1 Is the gtx 780 graphics card compatible with any pc? I want to but a cheap pc and change the graphics card to a gtx 780
Solution Phillip Corcoran Dec 22, 2014 Is the gtx 780 graphics card compatible with any pc? Not necessarily. The PC's motherboard must have a compatible expansion slot (PCI Express) & a suitable PSU that's up to the job (550w at least). Also bear in mind that the 780 is a "dual slot" card (it occupies only one slot but covers the slot next to it).
Phillip Corcoran Titan Moderator Sep 7, 2013 25,977 860 120,140 Dec 22, 2014 Solution #2 Is the gtx 780 graphics card compatible with any pc? Not necessarily. The PC's motherboard must have a compatible expansion slot (PCI Express) & a suitable PSU that's up to the job (550w at least). Also bear in mind that the 780 is a "dual slot" card (it occupies only one slot but covers the slot next to it). Upvote 0 Downvote Solution
