Ok so I installed a new H100i Corsair aio ever since then i have been getting luggish pc performance and bad game performance for example before the installation I was getting 244 to 300 FPS on fortnite now I’m getting 3-80 and all my setting are the same even times when I try to play rainbow six my movement with the mouse is delayed and I get bad FPS drops I checked my cpu and gpu temps and they are (at their highest when gaming)
41c for cpu and 48c for gpu with the cpu usage of 91% and gpu at 74% i used CCLEAN uninstalled most of my games to free up space updated all my drivers and checked for maleware and it’s still running poor and also removed pump from cpu cleaned off the thermal paste and reapplied then put back on like three times also made sure there was no dust build up but I only had this pc for like 3 to almost 4 months can some one please help me with this problem
me build spec are
Intel i5 9600k
Asus PRIME z390-a
Asus rog strix rx5500xt 8Gb
Team group T-force dark-z 32Gb ram 3200
Thermaltake 750 watt 80 gold PSU
Corsair hydro series H100i rgb platinum se
me build spec are
Intel i5 9600k
Asus PRIME z390-a
