Question I Need Help
Nov 19, 2020
My computer won't even post anymore
Spec
Ryzen 7 3700x
32gb 3200 ram
RX 560 mini (upgrading to the 3080 when I can get one in stock)
MSI b450i
I have 2 drives
A 500gb WD nvme drive
A 1tb Samsung evo ssd
A little backstory
In the middle of a game my computer crashed and boots me into safe mode
I decided to just reset but keep my files
It turns back on and works fine but half of games didn't run and kept giving me driver issues ( they were up to date)
So I moved all my files over to my 1tb second drive and then went to settings and fully reset my pc files and all (after unplugging my 1tb drive) after that I sat and waited for it and it got stuck in a boot loop showing the msi logo and then shutting off for about 20 mins straight after that I powered down my pc and then powered it back on and it didn't post . . . I unplugged the nvme drive and plugged in a different drive with a usb boot stick but the pc won't even turn on now and when I mash delete on the keyboard for opening the bios it my keyboard wouldn't light up or even as far as I know work . . .
Anything would help at this point I plan to get a friend to help me swap prices from his working pc to mine and vice versa so figure out what the issue it and if its more then just the drive . . .
I'd suggest that you create a bootable USB installer for Windows 10 using Windows Creation Tools and reinstall the OS. Also, you forgot to mention the make and model of your PSU and it's age.
See if removing the CMOS battery, while the system is powered down and disconnected from the wall, for at least 15 minutes helps your cause.
I created one but the computer won't even give me a boot screen and when I unplug all the drives and only have the boot stick it still won't do anything. Tried booting into the bios with delete on the keyboard but nothing
Its a Corsair SF600 and I bought it new back in June
I fully took apart the computer and then rebuilt it if I was a plug issue so that last step already done nothing
