i have some stuff on my nas not important stuff (like windows iso files and stuff like that) i tried to connect my qnap DAS in to my synology ds220j nas and it said it unable to connect to the usb device is there any way to fix it?
Question regarding:
"i tried to connect my qnap DAS in to my synology ds220j nas".....
Just how was that connection attempt made? What, how, etc.....? "usb device"?
More information and details needed.
Right. I have the TR-004.The QNAP TR200 is, to me anyway, not a true NAS. It is a storage unit using USB to connect to a host computer.
There are non-RAID ways of protecting from hard drive fail.........that are much less complex and more suitable for your apparent situation.all i know is raid 1 can protect you from HARD DRIVE FAIL ..................i dont wanna manually copy paste an hdd for 10 hours every day to diffrent hdds im pretty sure there are programs for it
Ye im sorry for the confusion i confused myself too this whole situation is a mess so its hard to explain but i will tell you, basicly K H and T are the data before i sorted it these are the orginal drives which i pulled all of the files from and dumped them on W i kept them as they were only for back up, W (and B are now the same) is the result of cleaning all of these drives
yesIs it true that K, H, and T combined contain 100% of your UNSORTED data files that you care about and want to preserve? And that only T is a RAID drive?
yes kind of.. see most of my unsorted files, were backups of old hard drives which i dont need and i forgot about and somehow i created another copy of the same onces.. if you understand what im saying.. so i just deleted both copies since i didnt need them, when i SORTED the files in to W i deleted the uneeded stuff and moved the important things betiwn A and W and to my NAS so i would say i do have my important things ready.If yes, do the combined contents of K, H, and T exist in SORTED form on any of your other drives? If yes, which?
i will try to calculate it and send screenshot of "my pc" folder to make it easier to understandIf yes, what is the combined space occupied on all 3 of those drives?
Ye these are the original disk before i made this post. K is copy of early version of A before i moved it to W (when i made this post) I saved it for backup. H is the hitatch disk, its even older copy of A but i found other partition of old copy of W in the same disk. T is backup of my old dying seagate drive in raid 1If no, then I don't follow your description of them as:
"On "K" and "H" and "T" I have old copies of my data before i sorted it".
ye thats whare i started and im still on my journy.. im not at the point when i can say that im fully satisfied but i can tell you one thing having the important data on "A" SSD makes me half satisifed since "A" mostly orginized and having the W data on other ssd feels more safe than having it on HDD i know i need to keep sorting but i wanna have like automatic backup of some kind (like file history or something) that i can recover some files if i delete something important while sorting.. thats kind of my goal at the momentI'd think your first goal would be to get ALL of your data in SORTED form on NON-RAID drives. Then worry about the next step. But I don't quite know where you are in that process. Maybe you have some other first goal.
yes and no since i deleted unneeded stuff and i moved stuff to A aswellI guess you mean that EVERYTHING is on K plus H plus T and that same stuff is also on W.
Yes W is raid 0 that i can format since its copied to ssd now (B). and T is raid 1 backup.And that W and T are RAID drives.
ye i did sorry about it i didnt know how to reply to individual quesstion beforeCan you answer directly any of the questions in post 37?
yes W and B are basicly the same one now i can format and break the raid 0 now on W. i know its 4tb but i made my W mess to be smaller then 2 tb so it fits to the 4tb ssd i deleted a lot of things and moved some files from W in to A and to another 2TB ssd that i carry with me on the goThis also confuses me: You say W contains "everything" and that B will soon contain the same as W. You say B is a 4 TB drive.
That implies that all of your data will fit on a 4 TB drive. In your first post, you say you have 18 drives totaling over 70 TB.
Yes and no my A drive is almost full But yes my W can fit in to 4 TB right now
No i just have "too much" of it in small amounts also these drives i listed here these are my big drives i also have some nvmes and smaller 1tb drives and 500 gb and so on but im not speaking about them right now since they are empty and i dont want to add more confusionIt certainly doesn't appear that you have a lack of storage.
yea kind of but we are getting there 😀 im sorry for the mess and i appriciate you for the help and everyone else too.. i will answear any quesstion to the best of my ability..I'm nearly certain there is a lot we don't understand or you haven't adequately explained.
i think yes to be honest i can never be 100% sure but i have my important things pulled out from the mess i mean lets say if for example right now if will lose these drives data i wouldnt care because i feel confidant i have my things that i need saved where i needed. (obviously maybe there are files i missed) but so far im not worried these drives i keep as "just in case"I asked:
"do the combined contents of K, H, and T exist in SORTED form on any of your other drives? If yes, which?"
You answered: "yes, sort of".
Keep going until the answer is an unqualified "yes". Not "sort of".
When done with that, let us know how many TB that adds up to.....ALL OF IT, one copy of each file you want to keep; sorted properly.
you should be able to upload the image to either of the sites below and then post that link in this thread.I took a screenshot of my disks situation how can i upload it? its not letting me
thanks, here we go :you should be able to upload the image to either of the sites below and then post that link in this thread.
Your pix may not be better than a description, but we'll see.
Postimages — free image hosting / image upload
Provides free image upload and hosting integration for forums. Free picture hosting and photo sharing for websites and blogs.postimages.org
or
imgur.com
Untitled — Postimages
postimg.cc
A is mostly orginized out of all of them. B and W are the same and they like 50% orginized. i have external ssd which is sorted too i copied stuff in to from the mess that i had in to it too.. and my NAS is sorted aswellI see 8 drives.
A B C H J K T W
Which of those 8 contain ALL of your data in sorted form? Name them.
Do those drives contain ONLY your data in sorted form and nothing else?
