I need RAM help
RAM is Random Access Memory, It is used by browsers, games, and almost every application on the computer. When your computer is shut-down, all the data on the RAM is deleted, making it convenient for holding files you do not need permanently. You can buy RAM off many websites, for example, Newegg, Amazon, TigerDirect, and many more. Choosing the right amount of RAM is based on what applications you plan on running, and I suggest you look at the solution I added. I currently have 16GB of RAM, but you can do fine with just 8GB or even 6GB. I would not recommend getting lower than 4GB.
right now i have 6 but for playing games i think i might want 8g. but i just dont know how like what kinds of ram and whta do the colors on my mobo mean
No. I cant afford that i am on a tight budget with this build. I already have 2 3g sticks so i have 6g in total but when i build it does it matter what color ram slot i put it in. Also i only want 2 or 4 more gigs of ram because im on a tight budget because i al ready have 6g
I only have 2 sticks and 6g so i think i have 2 3g. But i didn't know that mixing sticks wasn't good so i think that i will just get the two sticks you said. But those rae pretty pricy for my budget. Any other recomendations that are still good?
Desktop im not sure if its a 3g ram, but last time i checked, there were 2 sticks and i have 6g of ram. but my new motherboard has color codes, os can i install the 2 i have now in one color, and 2 new ones in the other color?
