Changed out a few parts that were garbage or not as good as they could be. Made a bit cheaper.
I would strongly recommend changing the mobo to a Gigabyte as you keep similar looks and enhance performance.
Yes the looks are different. I would stay with a cheap cooler until you can build a custom one. If I was forced to pick one it would be the H100/H110i GT. You want to change the PSU most of all. If you change 1 part it should be the PSU then the RAM and mobo. Corsair builds good and bad PSUs. The builder and C series are crappy.
Ok, and what do you recommend for a better PSU? I want at least 600w for future SLI
