I need some help
Jonathan_187
So for some reason lately my computer has been acting up and I have no clue what it can possibly be. For example my headphones I can hear people through them but for some reason I can't talk though them at all. Two I have a Logitech keyboard where it has LED lights inside of them and all of a sudden now it's only showing up half of the keyboard, don't get me wrong the keyboard still works but I'm not sure what the problem can be. I'm not sure if I have to get a new motherboard or something else
This is my desktop with my own things added on to it
http://www.bestbuy.com/site/cyberpowerpc-gamer-ultra-desktop-amd-fx-series-8gb-memory-1tb-hard-drive-black-blue/4593000.p?skuId=4593000
I have a nivedia 1060
And an SSD installed
Can you guys please help me I really want to know if this is a common thing or I need to buy a new motherboard
Keyboard: Problems with the lights should not be caused by the computer it is plugged into... As long as he keyboard recieves power, it should light up fully. Control this by plugging it in another computer. If it still does not fully light up, find the manual for the keyboard online. Maybe the keyboard has lighting functions you have enabled by accident..
Headphones: This is most likely the headphone jack acting up. If you have a single corded headset with mic and speakers, get a splitter online.
If you have 2 cords for mic and speakers, make sure they are plugged in correctly.
I have actually experienced some weird faults in the front panel where the computer would mess up the ports. Try swapping the green and red...
I have actually experienced some weird faults in the front panel where the computer would mess up the ports. Try swapping the green and red cables places, even if it's "wrong". It could be that your computer has messed up...
You can test your mic here: https://www.onlinemictest.com/
Sometimes if you're using Discord, your friends won't hear you even if your mic is fine, "because fuck you, that's why" - Discord Staff
