The fans on my graphics card are starting to get noisy, and lubricating them with some sewing machine oil unfortunately made no difference.
The card is an AFOX AF1060-6144D5H2
The info printed on the fans is as follows:
DC Brushless Fan
ID Cooling
Model: ND-8015M12B
DC 12V 0.38A
Searching online finds no exact equivalents, partly because of the way that the fans are mounted in the plastic frame.
Here's the card:
https://www.techpowerup.com/gpu-specs/afox-gtx-1060.b4864
So it's basically a GeForce GTX1060.
Looking for the model number of the fan (ND-8015M12B) doesn't help either as the matches I've found either have a different plastic mounting frame or they only have two wires (one fan on my card has four wires, the other has three wires). For example, this looks like the exact same fan and frame:
https://es.aliexpress.com/item/1005004253227093.html
BUT it only has two wires.
The following is almost there but the fans only have two wires each:
https://es.aliexpress.com/i/1005004253252450.html
Obviously two of the wires on mine are Ground and +12 Volts, presumably the other is a signal wire of some sort regarding fan speed?
Can anyone suggest where I could obtain the exact same fans please?
DC Brushless Fan
ID Cooling
Model: ND-8015M12B
DC 12V 0.38A
Here's the card:
