Hello, I'm relatively new to PC building, having only swapped out RAM and GPUs in the past.
My PC is working fine, but I'm worried about the high RPM showing on one of the fans, which I plugged into a Water Pump header for convienience (on the right of the ASUS Z690-A motherboard).
I can't reach the other headers. My question is, will this high RPM damage/wear down this fan, and how can I change it to match the others, assuming the readout is even correct? Thank you for any help.
TLDR: In summary, I'm told that any header is okay; but how do I match RPM with other fans?
