I recently built a first pc mostly for gaming. However after putting it together i got no imput on my monitor or power to any
0nThe3dge
Commendable
May 19, 2016
7
I recently built a first pc mostly for gaming. However after putting it together i got no imput on my monitor or power to any other outputs like keyboard. Ive tested with a different power supply, gotten a replacement motherboard but nothing works. All parts look to be working. Also beeper doesnt do anything.
My parts are:
Deepcool Tesseract sw
Intel Core i5 6500
Asus Z170-P
Corsair Vengeance LPX 16GB 2400MHz
EVGA 500B
EVGA NVidia Geforce GTX 960 SSC 4gb
Lite-on CD Drive
Seagate Barracuda 1TB HD
Asus VX228
Any suggestions for next step?
Ok, gonna need some more detailed info. When trying to boot, how far exactly does it get,if anywhere. Do you have a gpu, is the monitor plugged into the gpu or motherboard outputs, what output , is the monitor input same as the gpu output etc. The more detailed information, the easier to eliminate guesses.
When booting sll fans start, all lights turn on but idk how farbit goes because if gives zero output to the monitor.
Yes I have a Gpu. Have used HDMI and VGA buy neither change anything. I have also tried with and without gpu, plugging into gpu, but all to the same result. HDMI is the same imput as output but by VGA is a little different. Neither work.
