Hello,
Apologies if I posted in the wrong section, moderators feel free to move my thread to a more appropriate topic.
So here is the thing, i've been trying to get my dial-up modem to work for days, my dialling box pops up and then ends up with error 630, which has something to do with the modem, after trying alot of things (even reverting back to Windows 98 to make sure I have a correct operating system for my driver) and same results, until it hit me, what if my 25-pin to 9pin serial adapter is wrongly wired, I took out my multi-meter and ran a continuty check to trace where each pins heads off to, here are the results
(Edit: Here is a table to make reading a bit easier)
Is this the right wiring for a modem, also my cable says null modem on it, not sure what it could mean by null
Thank you, if I do indeed have the wrong wiring, it would be extremely helpful if you could send me some kind of diagram that shows me where each pin is supposed to connect so I can rewire it, thank you!
