Hi all, first time posting on this site and I'm not quite sure I put this in the right topic...
But anyways, on to the main question.
When I first got my pc, it was a referb. dell (i think) and since then I have added in upgrades 3 different times and switched cases.
Currently, my specs are:
CPU - Fx-8350 black edition, not overclocked
MOBO - Asus Sabertooth 990fx R2.0
GPU - Sapphire Radeon HD 7970 Vapor-X
RAM - (this might be the issue here, idk) I have 4 sticks of ram at 14 gb total(4,4,4,2) The 2 and the 4 are both stock samsung brand at 1333 mhz and the other 2 4s are Micron Technology 16jtf51264hz-1g4m1
PSU - I can't tell you the exact part here, although I can tell you that it is very likely either a Corsair CX500 or CX600
OS - Windows 7 Prof. 64bit
The reason I think that my pc is running slow is because when I look at my hardware and its specs it seems like I should get better performance than I do. I can't really put many games into consideration, but games such as Arma 3, crysis 3, battlefield 4, and others I can't name right now which I should be able to get 50+ (should be about 60) fps on AT LEAST very high quality I can't seem to get much more than 20-40 fps. This and in AMD Gaming Evolved's new program, I have said games "optimized" according to them and they still run very slow. I have also run Unigine's Heaven benchmark (1920x1080 highest settings, 8xAA and 16xAF along with extreme tessellation) and got an average of about 22 fps, when I read that with my config I should be able to get about 30-35.
I want to be able to play my pc at its optimal (or at least close) performance but I can't seem to even do that. Now, a lot of the stuff I have said has been my own opinion based off of my very minimal(compared to some of you guys) knowledge of hardware and research that I have done. This might be completely normal for my setup, but that I don't know and is thus why I am coming to you guys. Can I get an opinion on this?
TL;DR - Have absolutely no clue how my pc should be running, automatically assume it's slow.
