I think they placed my cooling fan backwards, the fan is facing towards the outside of the case.
Is this safe or useful or should i have it placed properly?
the fan is pulling air so that must mean its blowing air through the heatsink correctlyjust check which way it blows the air to make sure ;-)
Also, buy and install rear fan.
Good job m8 ;-)
i thought that too but since the gpu was working i thought one was all i neededBTW - your video card - shouldn't it be connected with additional 8-pin cable?
alrighty, so instead of going to the place where i got this installed i attempted to switch the fan myself. i think i got it installed correctly and hopefully havent messed anything up
heres what it looks like now, sorry about the bad angle before. this one is a bit better
can you tell if the heat sink is on properly? i matched the pic of the pc you gave me and it seems like its on right
also idk if its cause the fan is facing me or not but i am noticing some noise from the fan now.
YASSSi thought that too but since the gpu was working i thought one was all i needed
should i plug in the other one too?
yes it appears to be pushing air through the heat sink as the fan is pulling airMake sure the fan is pushing the Air through the heatsink towards the rear of your case. Looks good.👍
Another rear exhaust fan might help even more.
yes it has on both sidesRegarding the fan noise, does the fan have those red rubber pads on both sides? I see them in the picture, but they should also be on the side that is touching the cooler fins. If there are none, you will probably be able to pull those out and put them on the other side. This will provide some cushioning and a bit of distance between the fan blades and the cooler fins because it’s also possible the fan blades are rubbing against the fins a bit.
its plugged in too nowYASSS
its getting sucked in from the fanThe easiest way to check which way the air is going - get some tissue.
Put it behind the Heatsink (opposite side of fan)
Does it blow away or get sucked in?
It should blow away, like a flag
i bought some fans for my pc, gonna install one in back and front too
i also wanted to ask a quick question, i had to switch around the heat sink so do i need to reapply the thermal paste or is it fine since removed and attached the heatsink only about a day after getting it installed
cpu hovers around 35-38, gpu 35It would be best practice to reapply new thermal paste. Check the temps, if You are okay, then You are okay.
ok, temp is around 35-38 for cpuCheck the temps before re-applying.
It's still all fresh and we all know what a hassle some heatsinks are.
If the Temperature us higher than normal, re-apply. If they are normal, it means it should all be good
k, i reapplied the paste anyway and now see a slight improvementGPU's run a lot hotter than CPU's
Your CPU is fine
For extra Fans, you can buy Fan Splitters, that will run more than 1 fan from your motherboard -
https://www.amazon.com/fan-splitter/s?k=fan+splitter
okI ran out of headers on mine, and I use a splitter.
Perfectly safe
Just don't try and run 5 fans from one header![]()
