Question I think something is terribly throttling my ethernet speed,not sure what
Popikaify
274
6
18,795
I have really weird issues for the past few days.Basically if i open any web page in most cases it loads instantly sometimes may happen that i wait a second or two,some days watching youtube may cause stuttering and feel sluggish and i have to lower my resolution.Internet speed test only shows 30mpbs download and around 7mpbs upload,thats very low.
Aggregated Link Speed (Recieve / Transmit) says speed is 100/100 Mbps
Driver is updated ( Realtek Gaming 2.5GbE Familly Controller ) but under EEE Max Support Speed its 1GBps Full Duplex while 2.5 is available,and everything is on default because i also tried to reset everything.Ethernet cable is pluged into 2.5G lan port on my motherboard.Dont think my PC specs have anything to do with this.
B650 Tomahawk
7900 GRE
7800X3D
32GB CL30 6000 MHz
Corsair 750X 750W
So is the ethernet adapter setting for speed set to "Auto Negotiation" or a fixed speed?
Have you tried a different ethernet cable?
Have you also tried a wi-fi connection to test speed?
Reactions: Popikaify
This is almost always a bad ethernet cable when it is stuck at 100mbps. Try a new cable, you need nothing real special. Cat5e is fine but make sure it is pure copper with wire size 22-24. Lots of fakes cables sold so look for that information and avoid any that does not clearly state it. The most common fake cables are the flat ones.
I just replaced it with cat6 round cable and its still the same,hm
You're aggregated so given your scenario I'm just going to assume you're the only device plugged into your router. Do you have a router/modem combo or is your router plugged into your modem?
Also, the modem normally shows the connection speed to your ISP if you login and have a look. That would show if the speed is being affected from isp to modem then on to you, or if its a problem between and including your pc.
Have you tried a different pc with both ethernet and wifi seperately to isolate just your pc?
