Did you use a frame-rate increasing software, or did you manually add the new resolution and frame-rate? You've almost certainly gone beyond the capabilities of the monitor. Do as is suggested above, and try again. If you're overclocking your monitor, use EVGA's tool; it resets the frame-rate back to the original after 20 seconds if you don't click accept. Increase by 1 Hertz till the monitor blacks out, then lower it by one to find your maximum refresh rate. Mine is at 77Hz, but it occasionally doesn't recognize the monitor and needs to be restarted occasionally.
