[SOLVED] I Tried Running Driver Verifier
Fire099
23
I ran DV because I kept getting the error IRQL_NOT_LESS_OR_EQUAL BSOD occasionally. I ran DV and restarted my computer, of course it crashed but there was no BSOD and it just freezes. Right after Core Temp starts up. My secondary display (of two) then goes blank but doesn't say "No Signal", I can't use the keyboard but it lights up, same with the mouse. When I unplug the two, they don't turn back on. Windows booted me into safe mode a few times. When it did I tried to disable DV but it says "No Settings Changed" and there was also no drivers being checked. I made sure to create a system restore point for all of my drives, so resetting is an option, given it's the last one. I just uninstalled my Display Adapter and reinstalled it, which didn't fix it. What do I do now? https://www.dropbox.com/sh/p77uuptlr2xtryy/AABPBCDZScrBmgGx8qbhseZ7a?dl=0 (Minidump file)
Hi, I ran the dump files through the debugger and got the following information: https://waspiestmistake.htmlpasta.com/
File information:042620-11906-01.dmp (Apr 26 2020 - 05:36:37)
Bugcheck:IRQL_NOT_LESS_OR_EQUAL (A)
Probably caused by:memory_corruption (Process: ModernWarfare.)
Uptime:0 Day(s), 3 Hour(s), 09 Min(s), and 22 Sec(s)
File information:042620-10484-01.dmp (Apr 26 2020 - 06:46:34)
Bugcheck:SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007E)
Probably caused by:HIDCLASS.SYS (Process: System)
Uptime:0 Day(s), 0 Hour(s), 00 Min(s), and 34 Sec(s)
File information:042220-11656-01.dmp (Apr 22 2020 - 22:30:02)
Bugcheck:WHEA_UNCORRECTABLE_ERROR (124)
Probably caused by:GenuineIntel (Process: System)
Uptime:0 Day(s), 6 Hour(s), 14 Min(s), and 40 Sec(s)
File information:040420-9203-01.dmp (Apr 4 2020 - 22:46:55)
Probably caused by:memory_corruption (Process: System)
Uptime:0 Day(s), 3 Hour(s), 51 Min(s), and 37 Sec(s)
File information:040220-13125-01.dmp (Apr 3 2020 - 02:01:23)
Uptime:0 Day(s), 14 Hour(s), 27 Min(s), and 02 Sec(s)
Comment: 2 or more types of RAM are installed.
Possible Motherboard page: https://www.asus.com/us/Motherboards/Z170-PRO-GAMING/
There are BIOS updates available for your system. You are using version 1904 and the latest is version 3805. Wait for additional information before deciding to update or not. Important: Verify that I have linked to the correct motherboard. Updating your BIOS can be risky. Never try it when you might lose power (lightning storms, recent power outages, etc).
This information can be used by others to help you. I can't help you with this. Someone else will post with more information. Please wait for additional answers. Good luck.
