So I took out my old laptop hard drive, inserted a used ssd with an OS, the OS worked with the laptop, then I used the Reset this PC windows function. After resetting, the battery is not moving from 19%, without the charger the laptop will not turn on also. The battery says "19% available (plugged in)", I tried everything; Hard battery reset, reinstalling battery drivers, reinstalling windows from a flash drive, changed chargers. The only thing left is to buy a new battery. I also pulled the battery connector while the laptop is on, the status changes to no battery detected, then when I plug it back it, it returns to "19% available (plugged in)". Before I buy a new battery, is there another way I can try? I swear it was working before I changed my hdd to an ssd.
OK so as I was about to post this, the battery status changed to "22% 1 hr 25 min left before full charge" so I was excited I thought it was fixed. I pulled the charger then it died, now its at "22% available (plugged in)" and still wont turn on without the charger
heres the pic https://ibb.co/BZKtzRr
