i wanna change my power supply
Melker
70
hi! i'm gonna change my power supply but i wanna know if a power supply can destroy other stuff inside my computer if it has too high voltage? please help thanks :) have a good day!
A PSU can damage components if its made from bad quality components. Slight tolerances are ok but with cheap units, the voltages and supply is way off sometimes ...this leads to damage.
A good PSU will generally one that is rated 80% bronze efficiency or above.
Here is a guide to choosing a good quality unit that will be safe for components:
http://www.tomshardware.co.uk/answers/id-1804779/power-supply-unit-tier-list.html
If it has poor capacitors it can destroy your stuff.
