Question i wanna upgrade my pc for better fps and performance i got 400 USD what part should i upgrade first and what should i buy ?
You could've listed your parts like so:
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
include the age of the PSU apart from it's make and model. BIOS version for your motherboard at this moment of time.
^ would've saved you the unnecessary URL tags.
As for your upgrade, where are you located and what is your preferred site for purchase? Your thread title's encapsulated your budget(though a confirmation of where you're located helps us narrow down suggestions). You could swap out the RTX3050 and the APU for something higher end.
Reactions: stonecarver
Sorry, I am not going to check out all of your links.
My stock approach to this perennial question:
Some games are graphics limited like fast action shooters.
Others are cpu core speed limited like strategy, sims, and mmo.
Multiplayer tends to like many threads.
You need to find out which.
To help clarify your CPU/GPU options,
Run YOUR games, but lower your resolution and eye candy.
This makes the graphics card loaf a bit.
If your FPS increases, it indicates that your cpu is strong enough to drive a better graphics configuration.
If your FPS stays the same, you are likely more cpu limited.
