Question I will be planning to buy 4080 or 4090 and have 2 options for the monitor
Oh okay what if its 60hz
You will not be able to fully utilise the gpu. 1440p 144Hz or 4K 60Hz would be better suited to say a 3080 or 3090. Really you should be looking at 1440p 240Hz or 4K 120Hz or higher. Otherwise the gpu will be creating frames you cannot use. The 4080 and 4090 are extremely powerful, you really want an equally high end monitor to benefit from that performance.
If you are into gaming, 60 Hz gaming let me say not enjoyable & you will not be using your GPU fully. for 60 Hz 4K, 4700 would be enough.
I have a 9700 K, RTX 3070 and QHD 144 Hz monitor.
Previously my GPU was GTX 1070. Previously my frame rate was limited by the GPU. Now my slowest component is my monitor for many games (not all - for others it became the CPU) . That means if I replace the monitor, I can get more fps in QHD resolution.
Now for your case if you buy a RTX 4080 or 4090, your 4K monitor will be the limiting factor. And again 60 Hz is too low for such a build.
Ooo now I understood soo ill have to increase my budget alright sir thank you soomuch
4080/4090 can run any monitor you want.
Consider carefully your monitor choice. It will be with you for a long time.
If you can, go see your choices in person.
For fast action games, smaller faster monitors are what you want.
OTOH, if you play sims, strategy or mmo type games,
larger/wider/higher resolution is what you want. 120hz is ok there.
Becoz ill be taking a 32” monitor as i will be using it as my tv too will will that be okay?2k 165hz
