i3-6100 giving me low fps
runningice
Commendable
Aug 30, 2016
4
Specs: i3-6100 3.7GHz , MSI R9 380
I'm having single digit fps on game ( Tera Online ) during dungeon runs... i've heard that this game is cpu-intensive
Is i3-6100 really not enough to power up this game or are there other reasons(drivers,etc)?
CPU's dont have drivers, reinstall the GPU drivers. Best bet uninstall them and...
Yea many people says the game is poorly optimized, but didn't expect my computer to run it so poorly...even at lowest possible settings.
Whereas people using i5s told me they can get at least 30fps on high settings ):
I'm running it with MSI R9 380.
Is my cpu that bad for this game? (Duo physical core) since yours being quad core can fetch such high fps...
An i5 and only 30fps? Absolutely a shitty game! Not much you can do other than sending angry emails to the devs
No thats not the case because even though the I3 6100 has 2 cores its 2 cores are more powerful than my 4 running at 3.0 GHz, i would say that the game is just very poorly optimized and to maybe fix it you can reinstall you're drivers, it is what got me my 60+ FPS.
Drivers for my i3-6100? Alright i will definitely try it out
CPU's dont have drivers, reinstall the GPU drivers. Best bet uninstall them and use AMD Autodetect to reinstall them.
