Just to start I'm not too knowledgeable about pcs and this pc I'm talking about is a pre-build from PCSpecialist I've had for almost 2 years now.
Specs.
Intel Core i5 10600K @ 4.10GHz
ASUSTeK COMPUTER INC. TUF GAMING Z490-PLUS
4095MB NVIDIA GeForce RTX 2070 SUPER
32Gb 3000MHz RAM
So the problem is that yesterday I was playing a game and I noticed my pc was being really loud so I opened up speccy and saw that my CPU was a 95 celsius and it was idling at around 70-74 celsius. Whereas before it would be in that 70-74 Celcius range under full load. I don't have clear tubes for my water cooling however I can feel that one of the tubes is hot and the other is cold while the pc is running so im not sure that the water cooling is the problem. I have never reapplied thermal paste so that will probably be a reason for higher temps but I don't see how that would explain such a sudden jump. This happened once before and it seemed to just go away after I turned my pc on its side and was playing around with the water cooling tubes to try and feel the temperature from them but this time it's not going away.
Thanks for any advice in advance
Specs.
32Gb 3000MHz RAM
