G
Guest
Guest
manofchalk :
As long as you mount the board properly, you wont have a problem with it breaking under the weight of a heatsink. The backplate on most aftermarket coolers (including the 212 EVO) serves to spread the weight.
not disputing what you're saying just putting this out for the OP
with a new system; cpu, motherboard, ram and gpu; it is usually a good idea to "breadboard" it before putting it in the case. (it is not a big deal to remove the PSU and a HD from an exisiting case) so that way if you run across a problem it can be a bit easier to troubleshoot and immediately removes the possibility of a short.
point being: it is a lot easier to install the cpu and heat sink outside the case than inside. when you get done "breadboard" then just remove the graphics card to mount it in the case (leaving the cpu/heatsink and ram on the motherboard).
