i5-3570K bottle neck help
sto_
171
was up toms hardware
i plan on getting two evga gtx 970s but i was wondering will i have any bottlenecks?
also getting an as rock extreme4 mobo
my specs
cpu- i5 3570k @ 4.2ghz
gpu- gtx 660 sc @ 1149 mhz
motherboard- asus p8z77 v-lx
ram- 16gb corsair xms3 1333mhz
powersupply- corsair rm850
cpu and gpu both on custom water loop
Yes it should be fine , no worries. Your cpu is more than enough for gaming , and even the recent games , it should be able to do it without bottleneck ur gpu :)
Happy gaming
ptfpinho
32
It really depends on what game your gonna play , but the i5 3570k should to the job, so dont worry. And even if you gonna play those games that are more cpu hungry , if and if it will bottleneck it , it would be like 5 fps.. its not worth updating your cpu right now , so i would go with that specs and no worries :)
sto_
171
i plan on playing the newest most graphic and cpu demanding games i also have 3 24" montiors i use in sorround
ptfpinho
32
Happy gaming
Latest posts
