Hello. I've decided to overclock my CPU after many years. I have no experience with overclocking but I've used Intel God's "Quick and Dirty OC" thread as a guideline. I'd like some advice on whether I need to change some more settings in the BIOS.
Here are the BIOS settings:
http://i.imgur.com/gIxFGJG.jpg
http://i.imgur.com/ZbrvlF9.jpg
Stress Test Results:
Intel Burn Test (10 runs) + RealTemp: http://i.imgur.com/LN9CsMS.png
Aida64 + RealTemp: http://i.imgur.com/EdnuiB1.png (I made a mistake and clicked "Reset" in RealTemp during the Aida64 test, so the min temps are the actual readings at some point during the test.)
It looks stable overall. Idle temps are around 26-27°C. I just have to try some actual games and see how it goes. I am mostly concerned about voltages. BIOS shows a little bit higher readings than my actual settings. Same goes for Aida. They both Show voltages around 1.216. It's fine, isn't it? Only HWinfo shows these voltages (1.2V) that I set.
My PC:
CPU i5-4670K
Cooler Cooler Master Hyper 412 Slim
MB MSI Z87-GD65 GAMING
GPU MSI GTX 760 GAMING 2GB OC
RAM Kingston HyperX Blu 2x4GB DDR3 1600
HDD Seagate Barracuda 1TB
PSU Seasonic X-series 750W
Case CM HAF 932 Advanced
Is there anything else that I need to change in BIOS settings or is there something wrong/concerning with the current ones?
My PC:
CPU i5-4670K
