T tombops Reputable Mar 6, 2014 28 0 4,530 Mar 20, 2014 #1 90c seems to high it's at 1.22v do you think my cpu is not installed correctly
Solution RobCrezz Mar 20, 2014 tombops : I've clocked it back to the defaults im not sure if I wanna overclock now I would check the cooler is installed correctly, as if its not it will overheat even at stock clocks when it has load.
T tombops Reputable Mar 6, 2014 28 0 4,530 Mar 20, 2014 #2 I mean is my cpu cooler not installed properly it looks like its on a bit of an angle is that normal Upvote 0 Downvote
RobCrezz Expert Ambassador Mar 14, 2013 19,077 99 75,190 Mar 20, 2014 #3 tombops : I mean is my cpu cooler not installed properly it looks like its on a bit of an angle is that normal Pics? 90'c is too high. So yeah it could be installed incorrectly, or your chip is simply too hot for the 212 to keep cool at 4.3 Upvote 0 Downvote
T tombops Reputable Mar 6, 2014 28 0 4,530 Mar 20, 2014 #4 I've clocked it back to the defaults im not sure if I wanna overclock now Upvote 0 Downvote
RobCrezz Expert Ambassador Mar 14, 2013 19,077 99 75,190 Mar 20, 2014 Solution #5 tombops : I've clocked it back to the defaults im not sure if I wanna overclock now I would check the cooler is installed correctly, as if its not it will overheat even at stock clocks when it has load. Upvote 0 Downvote Solution
T tombops Reputable Mar 6, 2014 28 0 4,530 Mar 20, 2014 #6 Just reinstalled the cooler and I'm currently running intel burn test and checking temps with real temp so far its max temp is 65 Upvote 0 Downvote
RobCrezz Expert Ambassador Mar 14, 2013 19,077 99 75,190 Mar 21, 2014 #7 tombops : Just reinstalled the cooler and I'm currently running intel burn test and checking temps with real temp so far its max temp is 65 Thats more like it! Sounds like you have it solved. Upvote 0 Downvote
T tombops Reputable Mar 6, 2014 28 0 4,530 Mar 21, 2014 #8 That's not overclocked though its stock Upvote 0 Downvote
