i5 4670k overclocking temp guide please
Connor Wood
26
I'm overclocking my i5 4670k but I'm unsure on what temperatures to limit to.
I ran 20 torture tests on lin x and the highest temperature was 88 degrees using a hyper 212 evo cooler, with a 30 degrees celcius ambient temperature.
Should I lower the clock?
While some people will tell you that you should make sure its lower, others won't. I would, personally, keep it where its at and not go any higher. In a real world load, it won't get anywhere near that temp. If you haven't already, you can try dialing in your voltage a little bit. That might help with temperatures a bit.
